I have a question for someone with masonry experience, like Unofornaio, or anyone else. I'm building up my chimney with flue tile and 4" concrete block. I want to use some chimney block sections to avoid some need to cut every block. If refractory mortar the flue tile in place first, how do I get the heavy chimney block in place around it, without knocking it loose? Alternatively, if I lay up the block stack first, how to I get that little bead of refractory mortar in place two feet down a hole?
Any suggestions would be appreciated.
