To cast or not to cast?
  • Wlodek
    • Jul 2007
    • 134
    Right, a brief report is in order.
    I have been acquiring increasing amounts of bricks and collating a list of UK refractories suppliers (more than I thought).
    Still thinking about casting the top part of the dome. Thoughts (lose!):
    • thickness of the cast - the material will be similar to the firebricks used in the bottom rows of the dome, so do I need the same thickness? This would make the cast half a brick thick, which seems a lot. But if I don't I won't have the same thermal mass as the original
    • cracking - will it be liable to cracking due to thermal cycling?
    • how think are the Forno Bravo cast ovens? In the photos they look 2-3", which is far less than half a brick
    • and also - the top part of the dome would be probably approx. 50cm (20") in diameter - is this not too big as a single cast?
    • or should it be cast thinner and additionally rendered from the outside? Would that change anything?
    • or am I talking rubbish and I should just follow the plans ... ?
    Any advice, experience or suggestions, pretty please?
    Best wishes,
    W.
    "Carpe diem." - Fish of the Day (The Uxbridge English Dictionary)
  • wlively
    • May 2005
    • 384
    Re: To cast or not to cast?
    Probably best to read this
    and then ask ENZ since he is the only one I have seen do it. Now, I did cast my vent transition and a dome plug (approx 15" in dia and 3" thick). The material I used (KS-4) has held up great and am not worried about cracking at all, but it required a specific heat cure schedule. So you could not use it unless you cast pieces small enough to fit in an oven or had a friend with a very large oven/kiln.
    Wade Lively
