Re: Damper and door questions
Enquiring minds want to know.
Just how do I know if I need a damper?
When I fire my oven I can see that roughly the upper half of the oven is full of smoke and the bottom half is clear. I presume the bottom half is air coming in from the opening. Should it be more like 1/4 clear and 3/4 smoky?
So far the oven heats up in about 45 minutes with a good steady fire. Could a damper help it to heat up faster?
Thanks!
Thanks!
