I wonder how well a half dome barrel design would work for an oven?
Re: Half Dome Barrel?
Hey Two Jims,
The problem I found with a flat back wall is that heat does not bounce into the back corners when you are doing fire in the oven cooking -- so you don't get even cooking heat. That, and one of the back corners is inaccessible when you have a fire on that side.
How about turning that around James, put the door on the barrel oven side, dome and curved back to the rear of your oven.....This might give you some good air and flame control??
I just like thinking radical sometimes!sigpicTiempo para guzarlos.....
...enjoy every sandwich!
Then you end up with the same problem in the front. Cool, unable space that is difficult to reach and clean.
Been there. :-)
Not to be too serious about it, but the problems I had with my barrel fault oven were why I started FB in the first place. No there's an extreme reaction.
