Morning all. I finally finished the dome last night! Will upload some pictures soon as my build thread is non existent!.
Anyway, just the chimney now to overcome. Another user suggested a removable chimney to make it easier to cover the oven when not in use but to get the height you need for the draw. I like this idea but was left scratching my head around trying to fix the single skin metal flue I have purchased to the oven without cracking it etc.
The idea that I have come up with instead is to buy and cut a 150mm diameter clay drainage pipe and homebrew that in place to the arch with the help of a few surrounding bricks. My 6" flue should then hopefully be just a big bigger to slide over the pipe whenever I want to use the oven. If the metal expands then it has room to do so as it is not fixed in place. Aside from not using the oven in gale force winds, does anyone envisage a problem with what I am proposing? I would be really interested to hear any thoughts on this? The clay pipe would be around 12 inches high. no more.
