I have decided that the DuraTec chimney is out of my price range
and so I am going with 8x8 clay flue liners. My question is can I box these in with steel studs and Durock, or do I need to build a masonry chimney around the flue liners. My Chimney needs to be at least 4 feet tall, I may need to go 6 feet given the proximity to my garage, and that is a LOT of weight on my stand that I did not design for if I need to build a brick chimney.
My thought was to use steel studs and box it in to support the flue liners, and face it with Durock (or some thing similar) and fill the space between with insulation. Any thoughts, questions, criticisms?
Thanks,
DAN
and so I am going with 8x8 clay flue liners. My question is can I box these in with steel studs and Durock, or do I need to build a masonry chimney around the flue liners. My Chimney needs to be at least 4 feet tall, I may need to go 6 feet given the proximity to my garage, and that is a LOT of weight on my stand that I did not design for if I need to build a brick chimney.My thought was to use steel studs and box it in to support the flue liners, and face it with Durock (or some thing similar) and fill the space between with insulation. Any thoughts, questions, criticisms?
Thanks,
DAN
