I wanted to know before I finalise the design of the oven opening arch, whether a rectangular flue is an issue, it seems that a circular 6" flue pipe is suitable up to 36" and that would have a surface area of 182 cm squared. The alternative would be the rectangular flue which I think works out at 301cm squared so unless I've forgotten my geometry calculations from school the flow of air is at least 50% better if I go down this route - assuming that the height of the flue is the same for a fair comparison of course. Secondly, any strong feelings about suitable chimney height in a relatively sheltered corner of the garden, I was thinking just 400mm, but could afford and build up to 600mm if it would make a huge difference?
Here was my original post which got lost on my main build page as a topic:
1. For the size of oven (37inch diameter) is there any problem with selecting the following middle sized option of these cavity liners (by my calculations it has a larger surface area than a 6 inch circular flue) and would work well. *(see photo) they are 215mm x 140mm https://www.selcobw.com/products/bui...er-215-x-140mm and would be easier to connect to my intended rectangular exit through the oven entrance archway than a 6 inch diameter circular alternative. The 215mm x 215mm flue seems far to big for the purpose.
2. What height should I go to for the chimney, I've read a few thoughts and was planning on having three of these, connected with home brew mortar which would take the height up to 600mm from the point of connection with the arch, could/should I just opt for two and 400mm of height in the chimney?
) watching this video of thermal shock on a chimney tile. Insulating your rectangular chimney tile is a good idea as is keeping your flue clean. The insulation simply helps moderate the thermal shock in the flue tile material when you start up your oven. Generally, with a good smoke collection chamber (think of an upside down funnel that leads into your chimney) and normal firing of the oven, you won't see the extreme thermal shock generated in the video. Your flue will expand and contract slightly with firing/cool down, so leaving a little cushion between it and your chimney bricks is a good idea IMHO...
) in my background, but thermal loss would not be the problem with a larger chimney diameter. Since chimneys work best as they heat up a bit (increasing the draw), the problem I see with a large diameter flue is that it may not pull all the smoke up...you'd probably have a significant amount of smoke coming out the front of the oven as is going up the chimney. I suspect that if you used a piece of that larger flue to funnel smoke into a 6" to 8" pipe (normal size for a 36" to 39" oven) it would work really well. The smaller pipe producing the suction required to pull that smoke up into the intended path. Your transition to the smaller pipe would present some interesting problems, but I suspect it would be doable. I agree that it would be great to incorporate something of your Dad's in the build. You could also just stack them to the side of your oven and use them as a stand for your peel & other tools.
