Needing help with dpc2 venting
  • Needing help with dpc2 venting
    Hoping someone can help mr find answers.
    I have duravent 6dpc2 venting(6” duraplus canada 2) that I want to hook up to my outdoor oven. I’ve got a door coming and the plan is to build an arch, which will go to a flue gallery, upon which I want to mount an anchor plate to attach the chimney pipe to. I’m having a hard time finding which anchor plate I can use with that type of venting. If anyone has that answer I’d love to know, better still an answer supported by a reference would be fantastic. Thanks all.
    I can't tell if that is 2 or 3 wall pipe, but if it is 2 wall the anchor plate looks like you can find it by searching for "9441 // 6DT-AP".
    I found it looking at this duratec link
    Consistently the first to market with new innovations in venting systems, Duravent has captured a leadership position in emerging markets.
    My build thread
      Hi JR,
      thanks for the reply. It is a 2 wall pipe, with 2” insulation near as I can tell from the information on the box. I thought the DTC stuff might work, but I was worried about them not mating because of the different brand naming. Given the above you think the 6dt-ao should do?
        I've used duravent products on two projects and both times called up their technical support folks and got the answers I needed for what kind of adapter to use. They are great folks and I had no trouble reaching a live person when I called. Their advice is going to be better than anything I could tell you by looking at a catalog. They will give you the part numbers and you can search for the best deal.
        My build thread
          JR, thanks again. It took a couple of calls but I did get through. Found out from the person I spoke with that the duraplus canada 2 product line is actually the same as duratech premium. What I purchased is simply rebranded for the retailer I purchased it from. That made the rest of it easy. Thanks again for your help.
