After reading thru the primers & stickies, etc, I understand the passion of the pompeii oven on this sight as it pertains to making pizza's. I'm just looking for a little clarification, as I'm a little analytical.
1) The pompeii oven reflects heat better due to its dome construction as compared to the square rear corners where the arches meet the rear wall.
2) The pompeii oven is constructed in such a way that it's wall thickness is thinner than a traditional barrel vault (4.5" compared to 10" respectively). This translates to less thermal mass for the pompeii, which means quicker heat up time.
3) The pompeii oven is to be heavily insulated so that it can retain the heat, where the barrel vault loses it's heat slowly due to the higher thermal mass
Those are the three main differences that I could find here and on other sights.
My question:
If you were to build a barrel vault using the pompeii principals, (ie: 3"-4.5" wall thickness with the same amount of exterior insulation, same dome height, etc.) should it not have similar heat up and retention as a pompeii oven?
Any thoughts?
My question:
Any thoughts?
