Hi all,
Build time: Summer 2023
Method: david s home brew castable recommendation
I'm looking to try and find solutions to my pizza oven that has experienced some cracking both on the render, but also through to the inner dome. I also need to waterproof the dome as Winter nears here in the UK. Below is a full overview of the build. A few images of the build are included, along with an image of the cracking. Cracks in the largest places are 1.5-2mm. The main crack is also on the inner dome at around 1.5-2mm thick.
Construction method from bottom to top:
Stand
British oak mortise and tenon base with draw pegs
Base slab
Standard concrete mix, re-enforced
Insulation slab
5:1 perlite-crete - 10cm thick
Harth
50mm 42% alumina fire brick
Dome
Home brew castable, (3:1:1:1 Sand: Portland Cement: Hydrated Lime: Fireclay) with polyprop fibres.
Dome insualtion
8:1 perlite-crete, 10cm
Render
0.5/1cm standard British render with waterproofer agent. 6:1:1 sand, cement, lime.
Possible solutions
Cracking
Fill cracks with intumescent cement. It will still expand when heated, but won't allow quite the amount heat loss or water ingress. Intumescent cement can also have up to 25% flexibility when heated so will keep the cracks closed.
Waterproofing
Has anyone ever applied liquid DPM (damp proof membrane) to the exterior of the dome? The exterior rises to about 70 degrees c when up-to temp. I don't want to build a structure over the oven. Liquid DMP does still have a degree of elasticity to it.
Any recommendations would be greatly welcome.
Stand
Base slab
Insulation slab
Harth
Dome
Dome insualtion
Render
Possible solutions
Cracking
Waterproofing
