I'm curious if anyone has done something similar to this and if it's a good idea. I'm planning to do the first row with fire brick on end, cut 8.25" at the back and 7.5" at the front.
Then I will set up the indispensable tool for a 20" radius, 2.5" off the concrete slab.
Finally I will put 4" of insulation board in beneath 2.5" fire brick floor.
It gives me an oven floor with a 38.75" diameter and only 16" to the top of the ceiling.
That's the plan... so far... anyway
