Re: Smoke reducer
Jeanne, its very simple. I took a piece of aluminium, cut it to size so as to leave about 20 cm gap at the bottom and fixed it onto the two metal stands... you could use any kind of metal angle bits, or bend your own out of rebare - whatever works. It took me about an hour to make. You could even prop it up on two bricks as a try out, and make a nice one if it does successfully reduce the smoke.
I'm sorry to hear the smoke is still bothering you, but who knows, maybe this is the solution you're looking for.
Dave, you're very welcome
. So, did you fall in the fishtank yet?
