Last Monday I put a Calzone in a relativaly hot oven... and forgot about it.
Twenty minutes later I went to romove what was left... and what with hurrying and not being too chuffed about the situation, I dropped my y-tong door. Which broke into 1000 pieces.
In a fit of puique I then flung my wooden door on the ground, and it promtly broke in half. In my other hand I was holding the oven thermometer... after a short pause I put it down very gently - who says impulse control isn't my thing?
So here is the new improved door: 5 cm of Y-tong (aerated concrete) on the inside and my lovely singed, broken and glued together wooden doors on the outside. I stuck everything together with high temp glue - good up to 125 C. The concreat insulates quite well, so we'll see if that's enough.
The thing I'm wondering now is, what happens to glue if it gets too hot? Does it burn? Melt? Or simply stop sticking? Just hope there isn't a health hazard involved...
And if this doesn't work I'll try some high temp mortar I've got hanging around instead.
If it does work, it'll be a low cost, high insulation, easy to make door.
Not as nice as Jim's glass door of course... but even if I need to replace it once a year, it'll be a lot easier on the budget...
