I need a real basic primer on chimney's and vents. I've read the threads about Bernouille's Law of physics already. Chimney needs to get more narrow as you go up. That makes sense.
What about material? I haven't seen a discussion about the benefits/drawbacks of the different materials. I plan to completely enclose my chimney in a brick type enclosure. Does it matter if I use clay flue tiles vs. stainless steel (Duratech)? Is there a beneift of round over square?
How about this shape?
Does this have a better draw than the square? (hope you don't mind, Les, if I borrow your photo
