Hi guys,
I've built an oven myself from scatch using a relatively cheap method, which in short has a clay shell, with other layers of insulation over the top. I avoided the brick ovens because i didnt think i would be able to do the block work,
anyway...
my question is based on the finish coat of my oven which is a thin brushed on layer of sieved sand, cement and clay, with a little oxide for colour. I have since found out that this layer is not weather proof. when it rains, it seems to slowly wash off this thin layer.
can i use a comercial type sealer to possibly fix this problem? can you think of any problems that this may cause on my oven. ie chemicals near food??? is this a a big no no.
I hope you can help me
kind regards to all
anyway...
kind regards to all
