Insulation - top down or bottom up?
  • pizzahead
    • May 2008
    • 62
    I have placed my blanket oven my dome and put the chicken wire in place. I have heard that the vermiculite concrete insulation is hard to apply and was wondering if i am better starting at the top and working down or start at the bottom and work up?
    Any thoughts?
    Jase
  • egalecki
    • Mar 2008
    • 1049
    Re: Insulation - top down or bottom up?
    I wouldn't have been able to do it top down- I think you'll have to go bottom up. Just do it like a sand castle- wear gloves and pack it with your hands in layers going up. See my thread and you'll see the layers in the vermiculite!
    Elizabeth
    • RTflorida
      • Jan 2007
      • 1446
      Elizabeth is correct, I think it would be darned near impossible to go top down. It really doesn't like to stay in place; the chicken wire helps give it a bit of hold and working up gives you a base for each handful you slap on.
      RT
      • Ken524
        • May 2007
        • 1655
        Jase,
        I did my vermiculite insulation "bottom-up" with a slight variation to avoid troweling on that weird stuff.
        I put some hardware cloth loosely around the dome (to provide added support for the vermic) then I built a crude form around the structure with foam board (from Office Depot) and duct tape. Then I poured the mixture in the form and gently tamped it down.
        After a few days it set up very nicely. I did a couple of test fires and the board never got warm, so I left it there.
        Here are the pics from my construction thread
        NEW URL:
        http://www.fornobravo.com/community/forum/good-background-information/brick-oven-photos/2441-my-old-kentucky-dome
        Ken H. - Kentucky
        42" Pompeii
        • Les
          • Sep 2005
          • 2945
          Ditto - bottom up!
          Les...
          • pizzahead
            • May 2008
            • 62
            Yep, bottom up is the only way to go. That is horrible stuff to try and keep in place. Got about 1/3 of it done last night and it seems to have dried ok this morning. I reckon that has got to be one of the least fun jobs of building a WFO?
            Thanks guys.
            Jase
