I have started my WFO and my plan is to do a chimney centered on the dome similar to the oven used by Jamie Oliver on his cooking show. You can see the progress pictures of my oven and a discussion of the centered chimney on the forum under Brick Oven Photos the Florida Igloo project.
Anyway I found some pictures of the Jamie Oliver build on the internet here:
Jamie Olivers Project
When you look at the pictures it looks like they have built some sort of flat structure over the inner dome to support the chimney - at least that's my guess. It started me thinking - should I do some type of reinforcement of the dome to support the weight of the chimney? My plan for the insulation is to do 2" of ceramic batt and 2'-3" of vermiculite concrete over that. I could do a solid layer of vermiculite concrete just over the crown of the dome - with no batts underneath -to spread the load of the chimney. Anybody have any thoughts? How much weight will that inner dome support?
Lee
Lee
