I am trying to have the effects of a vent/draft door (in order to have a "bellow" and create a blast of air as id done in wood burning stoves). I am using a "door" (cement board one inch shorter than the actual opening) . I used this at the oven mouth an at the vent mouth with no effect.
I assumed that by allowing one inch of space at the bottom ,the air would flow with much greater intensity,however I noticed no change at all.
What am I doing wrong?
Thanks!
Thanks!
