Hello all - I had posted this in my Brick Oven Photos thread but didn't get any feedback, so I thought I would post it here also. I plan a chimney mounted center dome with the vent in the traditional front location. You can read more about that in this thread.
I have a quick question. I had planned on doing a clay liner all the way from the vent, across the dome and up the chimney. Since I am having to keep the transition flue in the insulated space between the inner and outer dome, I would like to keep it as thin as possible without messing up my draft. I was thinking something like a 6"X10" but when I look at the clay liners that is not one of the standard sizes - I would probably have to buy a larger size and cut it to narrow it. As I searched I found this product which looks like it would work well for me since it can be ordered thin and wide, is thinner walled than ceramic, is flexible and I can get in a 6"x11.35" size.
Oval chimney liner, stainless steel oval chimney liners, oval flue liner
Has anyone used this product here? I was worried about stainless steel - will that last pretty much forever in a humid environment like Florida's? Also will the fact that it is corrugated be a problem with the draft or keeping clean?
Lee
Lee
