Because my 8" DuraVent chimney will go directly through the peak of my gable-house roof, I'm thinking about building a square frame around the chimney at the peak (I guess you call it a "chase"). The frame would be covered with Hardibacker and then probably stucco. My questions are:
1) How do I seal this thing? Freeze/thaw/rain is a big issue here. Do they make a flat flashing that slides over the chimney? Would the flashing cover the entire top of the chase and fold over the sides, over the stucco (like this one)? Or can I just stucco the flat part and use a hi-temp sealant where it hits the chimney pipe?
2) If I use some type of roof tile (like slate or cement tiles), would I need more flashing at the intersection of the slanted roof tiles and the vertical chase?
I'm beginning to think I need to hire a roofer!
Here's the basic style I'm thinking of, though the chimney would extend a bit higher: Link
