I'd like to hard-wire a couple of lights into my gable overhang, pointing down at my landing, but I'm having trouble finding any recessed lights that will fit into my 2x4 gable (about 3.5" deep). Any idea where to find these, or if they exist? The alternative, I guess, is to install a light on the outside (under-side) of the soffit, but I'd really like recessed lights.
Recessed lights for gable?
Tags: None
Re: Recessed lights for gable?
depends how much light you want but here in australia 12volt downlights are popular but they do produce a fair amount of heat into the ceiling space and present a fire risk. another alternatve which I have in my house is LED downlights which produce little heat but take a little longer to get to full brightness when you turn on the switch.Real men cook with fire
My Oven and Fireplace Build
HD does sell a set of halogen down lights that are very small, and are for use under kitchen cabinets. They generate a fair amount of heat, so I would be cautious about direct mount to wood soffit. They are 110 volts, and can be dimmed with a standard dimmer switch. They have plastic housings, so you probably don't want them right over the opening.
Thanks Dave. I did look at those HD models, but I'm trying to avoid plastic. On a whim I googled "metal puck light" and found something that might work, though I'll need to use a transformer: link (the PK100 model). Maybe the Xenon option would be a little cooler in temperature.
Hi db
I think you will have a tough time locating pots like that. I know they have mico mini's for cabinets put I dought they would last in our climate. You might want to drop your fascia board to accommodate the pot. It would only be an inch or two. I hope this helps.
Regards Joe
Mississauga , Canada
Joe, that actually helps a lot! I hadn't considered making the fascia board larger than the trusses, lowering the soffit, but that should work. I'll definitely consider that.
And Dick, my wife loves those little white Xmas lights AND she wants a pergola someday, so that's another fine option. ThanksLast edited by dbhansen; 05-26-2009, 08:07 PM.
