I plan to put stucco on the upper walls (over hardiebacker) and stone veneer on the lower walls (over cement block) of my enclosure. I've read about all the flashing, weep screeds, etc. needed for installing stucco & stone on a house (especially here in the North), but are they necessary if the underlying walls are made entirely of metal and masonry products? I realize water vapor can pass through masonry, but does it matter for a WFO? Could freeze/thaw affect the bond between the mortar and block/hardiebacker? And do I need flashing at the stone/stucco junction for any reason, or will the mortar seal it well enough?
I'm thinking I can mortar the stone directly to the block and put stucco directly on the hardiebacker above that with no flashing, weep holes, etc. I will paint the stucco to seal it. Thoughts?
