I never thought I'd have so much trouble finding bricks for my decorative arch.... It seems like my only choice in clay bricks is between solid pavers that have a nice color on one surface only (and/or that don't come in the color I want), or clay house bricks (with holes in them
) that are colored by means of a sandy coating applied to the surface.
Is it OK to use the latter? The trouble is, the colored coating comes off with a wire brush, revealing the ugly brown/orange clay underneath. Does anyone have experience using this type of brick on the outer arch, and will the color wear off as I slide pans across it?
The other problem with these is that I wanted to use half-bricks, which means cutting them and exposing the clay on the cut surface (which will be showing on the underside of my arch).
I've checked all the brick suppliers in town, but maybe I need to look elsewhere....
Daren
) that are colored by means of a sandy coating applied to the surface.Is it OK to use the latter? The trouble is, the colored coating comes off with a wire brush, revealing the ugly brown/orange clay underneath. Does anyone have experience using this type of brick on the outer arch, and will the color wear off as I slide pans across it?
Daren
