hi guys,
just starting to use my barrel vault oven. I have gone through the curing fires with no real issues (some small cracks). my main concern is my chimney doesn't seem to draw enough of the smoke as it spills out the front arch.
I have made my chimney just outside of the door/opening. Im thinking of cutting out a small hole (size of half a brick) at the front end of the dome just above the door and feeding it to the chimney. Im hoping this will also help my fire to breathe as it appears to be choked by the excess smoke in the dome.
If i blast the fire with a hairdryer, it burns well, but soon after i move the dryer away it dies down again..
i will try and post a few pics of my oven. i will appreciate any feedback ond or advice on my situation.
EDIT: i also have a 3ft galvanized chimney flue which is detachable and is not in the pic
