I would say either. I have 8" (internal) round steel chimney on my 35
1/2" oven, and it works great. Though if you want to go with an
8"x12" clay flue liner that will also work. I did that on my 32x26"
oven.
>Dear James,
>I've come across the following table where on the left are the
>oven's diameters and on the right their chimney's minimum
>diameters.
>Diametro del forno diametro minimo canna fumaria in cm
>da 60 a 80 cm 20
>da 80 a 120 cm 25
>da 120 cm in su 30
>Our oven is 36" in diameter.
>Would it be OK to have an 8"x12" flue or an 8" would be
>better?
>Thanks,
>Stanley
oven.
>Dear James,
>diameters.
>da 60 a 80 cm 20
>da 80 a 120 cm 25
>da 120 cm in su 30
>better?
>Thanks,
>Stanley
