How are most of you building your domes ? as high vaults or low vaults? From what I?ve found on this site, a low vault parabola is the desired shape, while the high vault is basically a semi-circle ? the height is the same as the radius.
I?m about to start building the dome for a 39? oven. I want to make my dome a parabolic shape, but not quite as low as the plans call for (about 18? high vs. 15? for a 39? oven). Is there a good way to draw a parabola other than freehand guessing? I?ve found a bunch of web sites showing how to plot a parabola based on a formula, but I can?t find anything showing how to draw a parabola when you know the desired radius and height.
If the low vault parabola proves too hard to figure out or build I?ll go with the high vault using one of the jigs I found on this site. Is the overall performance of a high vault oven significantly different than a low vault oven?
Thanks for the help and info.
Freddie
Freddie
