Re: Duratech chimney exterior feels hotter than it should...
I found another thread that discussed leaving space between the stucco and the Duratech chimney and then filling the space with waterproof, high temp silicone sealant. That seems a lot easier than trying to add another chimney within my existing one.
Ah, good to know. Thanks!
So did you find a solution?
BTW, laser thermometers don't actually use the laser to detect the temperature, the laser is just for centering the infrared detector.
