Originally posted by ThisOldGarageNJ
View Post
Materials for Stucco Dome?
Re: Materials for Stucco Dome?
I used the acrylic fortifier in the 1st coat & plan to in the 2nd coat. I did pick up a jar of Quikrete's red. I was really looking to finish the dome in a burnt orange. The red is closer to what I like than the terra-cotta. I wish they had yellow... I could use that to make the red more orange. I'm going to experiment a little. Maybe if I don't use so much red, I might get sort of the effect I'm looking for.
hey wawa,
I finished with a damp sponge. gives you a slightly rough finish, but i like it, I just went out to look at the oven and there arent any hairs sticking out... If you finish with a trowel, you will get a much smoother finish.. Depends on what you like, but I dont think you will have any problems with hairs,,but if you do.. You could always get the hedge trimmers out !!
Cheers
Mark
are you going to be using the acrylic on the second coat ?
are you using color ??
Hey Mark... did the fiberglass fibers in the SBC bother you for using as the finish coat? I just did my 1st coat today and I've noticed that the fibers seem to stick out. Of course I didn't bother to do much smoothing, being the base coat. I'm not sure if smoothing would solve this. Just don't want to have needles protruding in case someone wants to run their hands across the beautiful finish. What are your thoughts & experience? Or anyones else's, for that matter, who has used Quikrete Surface Bonding Cement.Originally posted by ThisOldGarageNJ View PostHey wawazat,,
I used the Quikrete SBC,, I've said it Once I will say it a thousand times,,, LOVE THIS STUFF.... covered my block foundation and dome with it. Added the Acrylic fortifier for watrproofing and terra cotta color.. I have a 42 inch dome and used 2 bags just for the dome and that gave me 1/2-3/4 inch coverage...
For a smooth finish you can just trowel it on
For a slightly rougher finish you can trowel it on and wipe it with a grout sponge
One Note, You can mix by hand, but a mixer is recommended....
I also used half inch harware cloth for my vermicrete it worked fine,,,
Is there a reason your not using the vermicrete,,, Insulation is key to an oven..
Cheers
Mark
Quikrete has a pretty good tech line. I've confirmed that I do not want to use aluminum foil even for the sole purpose of protecting my insulation blanket until the concrete cures (so I can reuse it once the oven is torn down & reinstalled after my anticipated move). The foil will react with the concrete producing hydrogen and possibly causing air pockets and cracks in the concrete.
And concrete is strongly alkaline but is not acidic therefor posing no threat to the galvanized mesh... in fact galvanized mesh is encouraged for use as reinforcement for stucco.... as Dmun's former point above suggests.
My point above that I may have missed is that if it does rot out, You have already gained the structural strength of your vermicrete and stucco, and it probably really wouldnt matter. I used the half inch galvanized hardware cloth,, I have about 5 months in,,, and I guess I will never be able to see if it does rot, But I have had 3-50 lb grandkids standing and climbing on my dome and between the vermicrete and Surface Bonding Cement,, still not a crackIm not sure about rotting out, It may, My thought is that its used more as a form as well as holding down your insulation,
So use it and feel food about it
Cheers
Mark
Zinc is an entirely different metal than aluminum. The mesh that's designed to use with concrete, the expanded metal lath, is galvanized.What about galvanized steel? I ask because all the hardware cloth I've seen at the home centers are galvanized. Any reason I should not use that as my reinforcement layer for my concrete shell?
The linked article mentions acidity as a threat to galvanized steel; concrete is strongly alkaline.
Im not sure about rotting out, It may, My thought is that its used more as a form as well as holding down your insulation, It would be nard to put your vermicrete directly to your insulation... So it helps provide shape and something for the vermicrete to stick to, Then Stucco or SBC on top of the vermicrete..What about galvanized steel? I ask because all the hardware cloth I've seen at the home centers are galvanized. Any reason I should not use that as my reinforcement layer for my concrete shell?
Cheers
Mark
What about galvanized steel? I ask because all the hardware cloth I've seen at the home centers are galvanized. Any reason I should not use that as my reinforcement layer for my concrete shell?Originally posted by dmun View PostAluminum foil rots out in contact with the caustic portland products.
You actually can buy it,, THey use it in building in ground swimming pools, I though could not tell you if the mixture is correct, but there are posts in the forum of people have used it...My understanding is that you cannot buy vermicrete
Cheers
Mark
If I may make a polite suggestion, some of your questions would be -- at least in part -- alleviated by reading the free Pompeii directions. It discusses vermiculite and perlite based concrete...although I readily admit that I subsequently came to FB and asked a lot of questions about it myself.
My understanding is that you cannot buy vermicrete (as it is colloquially termed) mix. Instead you buy vermiculate or perlite (often in 4 cubic foot bags for reasons of economy) and mix it at some ratio (by volume) between 5:1 and 10:1 with Portland cement and some water. Having never made the stuff myself, I cannot offer advice from experience. I am merely restating what I've learned on FB so far.
BTW, it is frequently suggested that the Portland and water be mixed first, then the vermiculite added last (as opposed to blending the two dry ingredients and then adding water). I think there might also be a suggestion of wetting the vermiculite before adding it to the Portland slurry, but I am unsure what "wetting" means. Misted, drenched? I have no idea.
If I may ask, what kind of insulation board did you use? There are many options and I'm curious what path many people have taken.
My slab consists of 1 1/2" insulation board on top of 1 1/2" thick 16"x16" patio pavers on top of a 4'x4' 3/16" steel plate. I believe it feels hotter on the bottom surface of the steel plate than it does outside my 1 1/2" blanket when the oven is fired. Of course the bottom of the steel plate is inside an enclosure.
So would using vermicrete outside my blanket be like taking care to to insulate & caulk your windows, then leaving the windows open?? The blanket I used is rated to reduce 750? temps down to 161? and 1000? to 193?. Is the vermicrete layer worth the time & expense in my case?
Just in case; is this vermicrete a mix that can be purchased at my local Home Depot?
I've heard that the myths surrounding aluminum foil are complete bunk, that the shiny and dull side are completely identical and anyone could apply it in either orientation for any application with identical results. The difference in appearance between the two sides is simply a by-product of the manufacturing process, but it isn't, for example, a coating or anything like that. This is the claim made by someone who works in an aluminum foil factory.
What's the reference to the contrary, that one side behaves differently from the other for various applications?
Aluminum foil rots out in contact with the caustic portland products. In theory the shiny side could reflect heat back toward the oven, but in practice nothing but gold or platinum foil would stay shiny for long. I think the only thing it really does is trap moisture inside your oven and makes your curing period longer and more difficult.
I think it's one of those residual practices that someone once recommended, and keeps getting repeated. It's not actively harmful, like using sand for insulation, but I think it's pretty much useless.
How much board did you use ? how thick is your slab ? Is it possible your feeling heat from steam from the oven floor curing ?insulation board that is used under the hearth alone doesn't insulate that well. It gets very hot under my oven. I'll have to address that next time too.
I used 2 bags for the dome...Did the 2 bags cover the dome and walls?I stuccoed over the vermicrete.. I used the hardware cloth under it. But Im sure the 1/2 inch hardware cloth will be fine as the SBC is pretty thick and has fiberglass threads in it for structural strangth..How much did this stuff penetrate the 1/2" hardware cloth?goes over the blanket as an additional insulation, It is a mixture of portland cement and vermiculite, I used a 6-1 mixVermicrete
6 parts of vermiculite and 1 part portland with just enough water to make it like oatmeal.. The vermicrete is highly recommended, you may have trouble getting up to and holding your pizza temps without it... or you will burn a crapload of wood to keep hot..When using the SBC I added acrylic fortifier for waterproofing and Terra Cotta color was mixed right in... I used a sponge for my finish, sorry the pic isnt that good, i just went out and took it and its still dark here,,,SBCThis is usually not needed, some recommend against it,, I think in your case it may be a good idea if your planning on reclaiming your firebrick when you move, otherwise i dont think it is necessary.. THere is a theory that when Aluminum or copper foil is put on (shiny side facing the oven) it will reflect oven heat back in, There is also a structural use as a slip plane, which I honestly dont understand and Im hoping someone else can jump in here and explain,,,Aluminum Foil
I used it wet, kept a 5 gal bucket of clean water and rinsed it out every so often..Grout Sponge
Hope that helps,, keep the questions coming as thats how we all learn
Cheers
MarkLast edited by ThisOldGarageNJ; 08-16-2010, 05:47 PM.
Duh... right in your avatar!
Ok, I've seen your pix. So is the vermicrete you mentioned sort of a base coat concrete? I didn't realize this was a concrete substance... isn't regular vermiculite just poured in like a gravel/sand? Is that the brown layer? Did you use mesh for the vermicrete right over the blanket? Did you use another layer of mesh for the stucco? Did you finish your stucco with the grout sponge? Did you paint on your terra cotta finish?
