I wish I would have done a little more reading before I built my chimney! I built my chimney with red brick and the fireclay mortar (sand, lime, fireclay & portland cement). The chimney is 3' tall and the inside dimensions are 8 5/16" x 4 5/16" for a 36" oven. So it's too small to slip a 8 1/2" x 4 1/2" liner in unless I grind all the high spots inside the brick chimney and that may not be enough anyway. Is there something I can coat the inside of the chimney with to achieve the same affect as the clay liner?
Thanks,
Bruce.
Thanks,
Bruce.
