For my dome enclosure (to make it weather tight) I am going to use simple red bricks. I will be building a brick wall about 30" high and the longets stretch will be about 66". Do I need to double up the course for streth or add and thing behid it for strength?
Has anyone done something like this?
Thx
Thx
, you could build something similar with two layers of brick, but this would be more expensive, tedious and time consuming to do, and you'd still need the brick ties (in the old days, they used iron nails!!). Think of the space between the blocks and the bricks as insulation, too. Don't forget to drill drainage holes in the cement joints on the bottom course of bricks, or leave every fourth vertical joint open. Otherwise, you will probably experience condensation problems between the block and brick.
