Here's a really crazy design. I have, from the beginning, wondered if I could cover the thing in dirt and let moss, grass, and other weak-rooted (nondamaging) plants grow on it. I especially like the idea of terraces, as shown.
There are two major issues: preventing dirt, water, and roots from damaging the structure and building such a self-supporting structure in the first place.
On the first issue, I would put down several layers of heavy plastic and only make the dirt an inch or two deep so only small plants could grow in it. I would also provide good drainage off the sides, and maybe even slope the terraces a little so they run off the outer edge.
On the second issue however, I am less certain. This is basically a corbeled arch, which is notoriously weak. I would need to build annuli (flat rings) of rebar-enforced concrete.
The question is, do you think these concrete annuli can be built in such a way that they will support the load of the upper terraces (and a few inches of dirt)? How thick should the terraces be?
In addition, how the heck would I do it? If I form and pour an annular terrace in place, I won't be able to get the plywood out from under it! Could I make the concrete form out of that hardi-backer stuff (is this just sheet rock?) and then just leave it in place under the poured concrete? Could such a material be cut to this kind of shape?
On a related note, could I simply build the terraces out of hardi-backer (perhaps several layers) and not bother to pour concrete terraces at all? On major problem with that approach is there won't be any metal (rebar) to support it.
There must be a way to build this structure. It doesn't have to support much weight after all (just itself).
Is this totally crazy?
