Hello,
I am installing a casa 80 which will be covered above by an aluminum patio cover. Any suggestions on how to run the 6 inch stainless chimney stack? I would like to go straight through the cover but am unsure if heat from the stack would warp the patio cover over time. As it is, the top of the stainless stack if I did not extend it would be 3 feet from the top of the patio cover. The issue here is that the smoke may discolor the top of the patio cover. The other option is to run a few 60 degree angles and send the stack out the side of the patio cover so I would not have to cut a hole in it. Does angles in the stack decrease the efficiency of the draw into the oven? Any help would be greatly appreciated.
Anthony
Anthony
