Cinderblock to cementboard transition
  • Cinderblock to cementboard transition
    Hello,
    I was wondering if anyone who has done the steel framing to box in the oven has had any problem with cracks in a stucco finish? Someone mentioned having the blocks go up to a certain point and then meeting the cement board will cause a crack along the joint.
    thanks,
    David
    Re: Cinderblock to cementboard transition
    David,
    I did exactly as you described and didn't have any problems with the transition. Make sure you tape the gap between the concrete blocks and cement board. Also, tape ALL cement board seams.
    A have a few small stucco cracks in the back of my enclosure where I didn't bother taping the seams (oops).
    Good luck!
    Ken H. - Kentucky
    42" Pompeii
      I did the same - no issues -
      I used fiberglass tape at the transistion of the two materials and then used fiber reinforced render to coat the two surfaces (surface bonding cement).
      On top of that I put a final coat of a flexible stucco and it's looking great in year two.
      Christo
      My oven progress -
      sigpic
        Thanks guys, that makes for a little less worrying on my part, just finished the framing and going to start snapping the hardibacker today.
