Why is it important to use pearlite without silicone for pearlite cement insulation? If you look in the Pompeii Oven instructions under Hints and Tips They caution against using pearlite with silicone added and recommend using "horticultural grade pearlite". Can someone explain why? I can source the masonry grade with silicone easily. Getting the other requires me to order and ship.
Thanks Tom
Thanks Tom
