Perlite equal to Vermiculite?
  • Derkp
    • Apr 2010
    • 188
    Can I interchange perlite with vermiculite in oven applications?
    Does Perlite work as well for the insulation slab under the firebricks?
    Any tricks for mixing with concrete?
  • Neil2
    • Oct 2006
    • 1374
    Re: Perlite equal to Vermiculite?
    "Can I interchange perlite with vermiculite in oven applications?"
    Yes. Go for the "course" grained perlite.
    • kebwi
      • Aug 2009
      • 1090
      Mix perlite more gently than you would vermiculite. It is prone to breaking down to smaller and smaller particles during mixing. Other than that, they're basically equivalent.
        I used perlite and like the fact that the white color lets you know when it's fully mixed with the portland. But yes, they both work. You can either mix the dry ingredients and carefully trowel in the water, or mix the water and portland into a slurry and mix in the light stuff. This technique needs a mixing paddle in a power drill to mix the slurry.
        • Derkp
          • Apr 2010
          • 188
          Great! We have already bought 3- 4cu/ft bags, hoping it would work.
          How thick of layer do you think would be appropriate for a oven floor of 4 1/2 firebrick, the brick are 4 1/2 X 3-6 in X18 long, and overall oven dimensions (inside) of 28 X 36?
          Thanks,
          Derk
          • Neil2
            • Oct 2006
            • 1374
            four inches
            • Mitchamus
              • Aug 2008
              • 389
              If you're mixing in a wheel barrow - add the water slowly.
              If you just dump half a bucket of water in - the Perlite will fly out of the barrow and go everywhere!!
              (don't ask me how I know...)
              My 2nd Build:
              Is here
              • Neil2
                • Oct 2006
                • 1374
                Mix gently. Try to avoid breaking down the perlite particles.
