oven option?
  • caymancooker
    • Jun 2010
    • 2
    oven option?
    we dont have fire brick or any clay bricks on island
    but i do have a 36" round x26 deep unglazed fired clay pot(new)
    could i add mass and insulate it to form an oven??
  • PsychDoc
    • Dec 2012
    • 76
    Re: oven option?
    Good question!
    I have tried a "rocket stove" under a terra cotta pot and easily obtained 600 degrees, this was my proof of concept. I started, today, a larger version. It will be large enough to place a 13" pizza stone and test the durability of a large clay pot. My hunch is that ovens get to be much hotter and could crack a pot. However if the thing doesn't explode it may provide an inexpensive and time/labor saving alternative.
    I shall post my progress
      • 9216
      Re: oven option?
      You could easily cut a door in that pot with an angle grinder fitted with a diamond blade. Make the door height about 63% of the interior dome height.
      On rocket stoves, check this out, it's a clever piece of kit.
      BioLite - BioLite Stove
      • PsychDoc
        • Dec 2012
        • 76
        Re: oven option?
        You don't need the diamond blade. I used a $2 masonry cut/grind blade in tha angle grinder and sliced a pot with no problems.
        So... cayman, get a move on. I want to learn from your success!
        Get the diamond blade. It is sooooo much faster for straight cuts
          • 3885
          Re: oven option?
          What are you going to use for extra thermal mass? Is there any natural clay on the island. I think that I saw some masonry construction on Grande Caymon. At least a couple dozen banks per block if my memory serves me .
          Seriously, I would love to see this concept attempted. I think that a terra-cotta pot would be, at least, a great form for some type of refractory mass should the pot fail, and it probably will eventually. A clay/portland/hydrated lime shell should add a long life to the oven.
          Like David S. and Wotavidone suggest, keep the door to dome height as close to the 63% as possible. Insulate underneath the floor and around the shell as much as possible.
          I would love to see pics and posts of your progress.
