S.E. Quensland Suppliers.
  • BackyardPermaculture
    • Mar 2010
    • 151
    #31
    Re: S.E. Quensland Suppliers.
    The rockwool blanket was pretty easy to just drape over the dome; I can't comment on rendering over it because I housed it, but there are lots of posts on here describing vermicrete mixes over insulation.
    My Clay Oven build:
    http://www.fornobravo.com/forum/f43/...dah-12821.html
    • jarredv
      • Oct 2010
      • 2
      #32
      thanks buddy. one other thing have you tried using charchol for the fire instead of fire? im told its better because of the no smoke factor?
        • Mar 2010
        • 151
        #33
        I haven't tried charcoal; I use a "top lit" or "upside down" fire. It has a layer of big wood on he bottom, then smaller wood, then smaller again, then the little twigs on top and a couple of fire starters. Once the tinder on top burns a bit there's almost no smoke - works really well.
        Cheers,
        Mick
        My Clay Oven build:
          #34
          Bagged charcoal is ruinously expensive. Unless you buy the top name brand, it's mostly bituminous coal, which you can buy dollars a ton. It doesn't much smoke (nor does firewood once you get your oven hot) but it does smell nasty.
          • amc27227
            • Apr 2011
            • 2
            #35
            Hi Every one. I am new here so sorry if I am posting in the wrong section. I was wondering if any one here knew where I could get ball clay in the south East QLD area?
            thanks in advance
              • 9216
              #36
              For ball clay go to Pottery Supplies in Brisbane, but if you meant fire clay then go to Claypave also in Bris.
              • amc27227
                • Apr 2011
                • 2
                #37
                that's great, thanks David S!
