I am making my own refractory mortar/cement as described in the Il Forno book using Fire Clay, Portland Cement, Lime, and Sand. I would like to get the ration of materials in the mix.
Need the ratios for mixing refractory cement
Tags: None
Re: Need the ratios for mixing refractory cement
This link will really really help you:Cement and Sand Plough Mixing Machine products, buy Cement and Sand Plough Mixing Machine products from alibaba.com when it comes to mixing refractory cement.___________
Black GraniteComment
Parts ratio is 3x2x2x0.5, plus water
3 shovels of the gravel or crushed firebricks
2 shovels of sand
2 shovels of the cement
half shovel of lime ( hydrated lime)
This amount will require approximately 6-7 liters of water to mix the concrete.
The website this came from is Refractory concrete mixing recipe | Refractory concrete ingredients for wood ovens.
You can save much $ mixing your own.Comment
Lee B.
DFW area, Texas, USA
I try to learn from my mistakes, and from yours when you give me a heads up.Comment
