Need truth about home brew refractory
  • scottstropko
    • 2
    I live in the "sticks". Just returned home with a load of refractory HiCast only to find that it is no mortar. There goes a 6 hour drive and lots of $4 gallons. Can anybody tell me just how dissapointed or happy I'll be if I use the FB refractory mixture ratios using lime, fireclay, portland, and sand? Help!!
  • cynon767
    • Dec 2008
    • 230
    Re: Need truth about home brew refractory
    Two years on, and I'm quite happy with mine. I used a mix similar to the basic FB mix, with about 3.5:2:1:1 of sand, fireclay, cement and lime. Ask me in another 20, but I expect it will still be standing.
    It takes a little longer to cure fully, but it works pretty well. I did some looking into this same question a couple years ago when I was building, and discussed it here: http://www.fornobravo.com/forum/28/r...html#post72280
    I say go for it, and best of luck!
    -jamie
    My oven build is finally complete!
    • rodeair
      • Oct 2010
      • 163
      I used the 3:1:1:1 homebrew for my oven. I don't have the long term result, but I was sold on the cost, workability, etc. Never used the premix, but my experience with the homebrew was all positive.
      Leigh
      • scottstropko
        • 2
        Just want to say "Thanks" for the info. I needed to be sold on a direction. It has taken me all summer to get to the dome, and I'm looking forward to doing it right. I read your thread you referred me to and am now comfortable with a homebrew. Thanks for your research!
        • nissanneill
          • Apr 2007
          • 1886
          Go with rodeair's formula!
          I used it 4 years ago on my 40"Pompeii with great results and no cracks even today. I would not use anything else!
          Neill’s Pompeiii #1
          Neill’s kitchen underway
          • C5dad
            • Oct 2005
            • 422
            I too use the 3:1:1:1 mix and have been well pleased with it. Cant go wrong. Just mix in small batches (for me - each # was a red party cup!.) You will need to play with the water as hydration will vary according to area. Down here in AZ, I used about 1 3/4 cups water per batch.
            Your mileage will vary.
            Follow my build Chris' WFO
