Is there any problem with using Insulating Firebrick instead of Fireclay Firebrick?
Types of Fire Brick
Re: Types of Fire Brick
Insulating brick could be used for back up insulation, although it wont insulate as well as fiber or cal sil board. If you are picking up your cal sil board, ask to look at both insulating brick and fireclay brick - its easy to see the difference. -
Ins bricks wont hold any heat. Forget about them unless it is for the base.Comment
