foam concrete
  • pfennigthecat
    • Nov 2012
    • 62
    #61
    Re: foam concrete
    I'm new to a lot of the WFO stuff, but is this likely to be the method of choice for hearth insulation, pouring an insulated layer on the hearth rather than using ceramic boards or the like? is that the 'end goal' behind the experimentation?
    I think I read correctly that it is a very liquid mix, so would you anticipate being able to use it anywhere else? Build a form around a completed dome and pour to embed the dome in a solid cube of foam concrete?
    Lastly, are you using your home-made foamer for the tests still, but using the 'official' foaming liquid?
    Thanks in advance! I'm just starting thinking about getting materials together right now, would definitely like to know if there is a better / cheaper option for insulation under the floor or over the dome.
      • 9208
      #62
      Re: foam concrete
      Yes, I use my homemade foam generator, it works fine, but you need the correct foaming agent which produces foam that does not deflate and is chemically compatable with the cement. Calcium silicate board is probably a superior solution, but it is expensive (for where I live at least)
      Forget about using foamcrete over the dome, unless you have some sort of outer mould to contain it. It refuses (in my experience at least) to work up to a plastic mix. If you are doing an enclosure it is probably better to use loose dry perlite or vermiculite, although you could cast a solid cube of foamcrete, let it dry and stucco over the surface for strength.Come to think of it you could easily sculpt the foamcrete cube into whatever form you wanted.
        • 9208
        #63
        Re: foam concrete
        Here are some photos of my homemade foam generator that I've been using successfully for a while now.The first shot shows the internal bit, the second one shows the position used when adding compressed air with the tap in open position. It takes about three minutes for the foam to start coming out the tap.The last shows the position I use when pushing the foam out. I use bike floor pump for this as it is a better controlled way of pushing out the foam. As you can see it produces 20 litres of foam from a charge of 20 ml concentrate and 2 litres of water (this needs to be calculated in the total water addition of the mix). You make up a slurry of cement, then add the foam to it either in a mixer or barrow. It is ridiculously simple.
        • waikato pizza
          • Oct 2012
          • 48
          #64
          Re: foam concrete
          so what do you use as a foaming agent? Dish washing liquid?
          • brickie in oz
            • 3445
            #65
            Re: foam concrete
            http://www.fornobravo.com/forum/f44/...tml#post139631
            • RogerQ
              • Jul 2012
              • 3
              #66
              Re: foam concrete
              I salute you for building a foam generator! From some earlier reading, there was a problem in exporting organically based foaming agent to India; blood was used in the production. If I remember correctly, the inorganic agent was sodium lauryl sulphate.
              As an alternative to clay slip, there are castable refractories available, and investment casting, (sort of a lost wax process). They are designed to gain strength from drying or curing, then even greater strength when they are fired.
              Carry on! I'm back to your pdf's
              roger
                • 9208
                #67
                Re: foam concrete
                roger
                Using the foam in conjunction with castable refractory is on my to do list. Unfortunately there are way too many other things higher on the list.
                  • 2848
                  #68
                  Re: foam concrete
                  roger
                  Gudday Rodger and Davids
                  Blood and bone was the main component of the old style fire fighting foam. Its use has been taken over by AFFF which main component is of course sodium lauryl sulphate, Sodium lauryl sulphate is also found in most hair shampoes ( check the label out on yours). Sounds like making this foam cement might be lot more achievable by the home handyman than I first thought.
                  Regards Dave
                    • 9208
                    #69
                    Re: foam concrete
                    The chemical composition of the stuff is on post no. 14 on this thread.
                      • 2848
                      #70
                      Re: foam concrete
                      Oops
                      • WesinThailand
                        • 20
                        #71
                        Re: foam concrete
                        I used the "air block" as insulation under the hearth of my oven - essentially the same as the "foamed concrete", I think. No problems so far; seems to hold heat and the blocks are set on edge, giving me 7 inches of insulation, with the hearth floating on top. I posted photos on this site.
                        • brickie in oz
                          • 3445
                          #72
                          Re: foam concrete
                          A vid on foam concrete, anyone speak Spanish?
                          Foam concrete - YouTube
                          • WesinThailand
                            • 20
                            #73
                            Re: foam concrete
                            Blocks of foam concrete are being used in general construction here; taking the place of wall insulation and a small, soft red brick. I assume they are not quite as strong but they are certainly lightweight, cheap and make buildings cooler. I have no idea how they are manufactured here in Thailand - I just hope they ones I used last a long time. They can be replaced(in my oven) but it would be a pain. I fired my oven the first time, about a year ago and used it 2 times a week on average.
                            • robinwham
                              • 10
                              #74
                              Re: foam concrete
                              I'm in Folsom, CA and looking for the "ceramic fiber insulation board" used on the oven stand beneath the oven floor. Any local sources?
                                Re: foam concrete
                                Forno Bravo (our hosts) should be reasonably close to you .
