Hi everyone
I've been getting mixed oppinions about the spacing between the firebricks for the actual wall and dome of the oven.
As per the fornobravo design, the bricks are tight and come into contact with each other (face side of oven) and the back side of the bricks often have a small half inch empty space wedge of air that is supposed to get filled with high heat resistant mortar. I've been told that the mortar properties are different from the properties of the actual fire bricks in that the mortar is only able to resist heat where as the bricks are made to retain the heat. For this reason, because the two properties are quite different, the mortar is supposed to be used sparingly (no thick layer) as a high heat resistant glue to hold the bricks together. I was also told that because the mortar is supposed to be used thin layer as opposed to thick layer, the latter would imply that I am supposed to cut the bricks so as to reduce the amount of spaces between each brick on all sides. Basically the tigher the fit between bricks the better it would be because it would require less mortar, which is a good thing because if too much mortar is used, it becomes counter productive.
In the Fornobravo plans, the pictures of the brick laying appear to have healthy spaces of air between the backside of the bricks, which then get filled with mortar. Is this a concern for the effectiveness and longevity of the oven? I realize it's a lot easier to go this route but is it better construction to take the time to cut each brick with the necessary angles from all sides to minimize the space between bricks and use less mortar? Someone even told me that because the mortar resists heat and the bricks absorb the heat, because the two properties are so diiferent that if too much mortar is stuffed between the bricks that over time they could fall off.
Can someone please shed some light on the above because cutting every brick to measure, to fit as close as possible in every way to the neighboring brick, will take a looooong time!!
Thx in advance
Nick
Thx in advance
Nick
