3:1:1:1
Old World Stone & Garden
John Ruskin -
Re: 3:1:1:1
Permanence is ambiguous with natural products. The way clay is used effects how it performs...and what the final result is. Understanding how natural products work and the way to use them is the challenge.Originally posted by wotavidoneExactly - no cement, no lime = very lean to me, because I don't see clay as a permanent binder unless you can get it hot enough to "fire". Until then its a reversible thing that must be protected from moisture, etc.
But that's fine, see it the way you want.Last edited by stonecutter; 03-19-2013, 07:04 PM.Old World Stone & Garden
John RuskinComment
Re: 3:1:1:1
As clay is composed of decomposed rock, millions of years old, it is essentially superfine sand (an aggregate) but because the particles are so fine they attract one another. This is what gives the clay it's strength, but it is still only a mechanical bond. It hasn't changed chemically (like cement or lime) until it gets fired (over 573 C) I think the moisture protection thing is not too much of a problem. Clay with quite a high moisture content is still as strong as fully dried clay. In some cases I think it is actually stronger. Try smashing a block of partially dried clay compared to a fully dried one. Clay is also used to line dams to create a waterproof layer to hold the water in. Pretty versatile stuff.Originally posted by wotavidoneExactly - no cement, no lime = very lean to me, because I don't see clay as a permanent binder unless you can get it hot enough to "fire". Until then its a reversible thing that must be protected from moisture, etc.Kindled with zeal and fired with passion.Comment
Re: 3:1:1:1
The strong points of clays are generally when they are wet (sealing reservoirs) or kilned (brick). In between they are unstable, and subject to large swings in volume.Comment
Re: 3:1:1:1
But it's the in between parts that you can do beautiful things with the stuff. Free and abundant, it's a god given substance.Kindled with zeal and fired with passion.Comment
Re: 3:1:1:1
Did you miss post #3?Originally posted by Karangi Dude89 Posts later has anybody actualy answered poor Gianluca question????
Gian, I hope you have not hanging by your thumbs waiting!!!!Old World Stone & Garden
John RuskinComment
Re: 3:1:1:1
Yeah it did go off topic didn't it. The OP probably ran off because a bunch of kooks were talking about clay.Originally posted by Karangi DudeNo I didn't miss post #3
That answers the 1st part of the question!!
Why don't you enlighten him?Old World Stone & Garden
John RuskinComment
John RuskinComment
Re: 3:1:1:1
The fireclay has finally started to set, I think it may well work for a barrel vault, if not for a Pompeii. I am burning the test cubes today to see how it hold up, but I am sure it will be fine.1 PhotoComment
Re: 3:1:1:1
OK, that didn't work. It disintegrated completely and did not even leave a residue on the brick, indicating zero bond strength.1 PhotoComment
Re: 3:1:1:1
I accidentally broke the cubes, they were too big to move easily. Both stayed adhered to one side, I will see how soft they are when they cool down.1 PhotoComment
Re: 3:1:1:1
If you taper the bricks in the critical, near-vertical areas, and rely on the mortar only as 'chinking' to fill the gaps, bond strength is almost irrelevant. Although "disintegrated completely" sound bad for the clay/sand mix... if you have enough residual strength to keep the mortar from trickling out the gaps, almost anything should work (with tapered bricks). I'm a big fan of tapered bricks. Two years ago, I used Heatstop 50 -- next time I won't
