calcium aluminate, fondu, lumnite help
  • cfield
    • Apr 2013
    • 2
    I am having a hard time finding a supplier for (10) 94lb bags of calcium aluminate for an oven. It is also refered to as Fondue, or Lumnite. I'm sure that the information is on here but I haven't had any luck. Please let me know if anyone has any help. I am located in Eastern Pennsylvania.
  • shuboyje
    • May 2009
    • 406
    Re: calcium aluminate, fondu, lumnite help
    From the quantity you are looking for I assume you are going to cast an oven. I highly recommend a commercial castable refractory for that use as opposed to a home made mix using Calcium Aluminate cement.
    • Wiley
      • Mar 2008
      • 804
      Also you may have better luck with searching using Fondu as the spelling. When I bought the Fondu I used it came in smaller sized bags than the usual 94 lbs. You know the reason for the 94 lbs? It is because that is the weight of a cubic foot of portland type cement. Concrete is mixed/measured by volume rather than by weight. Fondu is a specialty item and as such comes in smaller bags.
      Hope this helps,
      Wiley
