Too dirty?
  • Telmah
    • May 2013
    • 7
    Too dirty?
    The previous owners of the house I am about to buy have used hundreds of fire bricks as pavers for paths. They have been in the ground for 7-10 years. Can they be cleaned up and used in an oven? Any recommendations on how to clean them?
  • SCChris
    • Jun 2009
    • 1213
    Re: Too dirty?
    Wash and scrub and then dry them. Are they really firebricks?
    Chirs
    • jeeppiper
      • Mar 2011
      • 321
      Re: Too dirty?
      they are probably red clay bricks, not fire bricks.
      • SCChris
        • Jun 2009
        • 1213
        Re: Too dirty?
        Jeep, That's my bet too.. But just in case..
        Chris
        • brickie in oz
          • Mar 2009
          • 3445
          Re: Too dirty?
          Pictures, we need pictures.
          My Build.
          Books.
          • nissanneill
            • Apr 2007
            • 1886
            Re: Too dirty?
            Easiest way to clean any "dirty" bricks is with a pressure washer with a wide adjustable p]spray rather than a pencil jett them drain and then mortar them into place.
            Neill
            Neill’s Pompeiii #1
            Neill’s kitchen underway
            • Telmah
              • May 2013
              • 7
              Re: Too dirty?
              Definitely firebricks, yellow with clean, sharp edges. Tough too, a 1000lb limb from a locust fell and drove several 2-3 feet into the ground, I haven't found any broken pieces yet..
              I am trying to attach a picture now... Here goes.
              • michelevit
                • Mar 2008
                • 106
                Re: Too dirty?
                if you already have a pizza oven, cook them!
                The high heat will clean them nicely. Make sure they are dry.
                • Tscarborough
                  • Oct 2009
                  • 3341
                  Re: Too dirty?
                  You don't need an oven, just build them into a very loose pile and build a fire on top of them.
                  • Telmah
                    • May 2013
                    • 7
                    Re: Too dirty?
                    Thanks! Great idea. Don't have an oven yet, but I do have a couple of campfire rings, and can make a makeshift fire pit or kiln-like structure...
                    • Telmah
                      • May 2013
                      • 7
                      Re: Too dirty?
                      Here (finally) is a picture- dug 400 or so of them out of the garden paths. Can anyone tell by looking what type of firebrick these are?
                      • boerwarrior
                        • Apr 2013
                        • 454
                        Re: Too dirty?
                        you could weigh them and then measure the dimensions to calculate the density.
                        After you know that, here is a good reference that could help:
                        Firebricks are actually fire clay bricks. Thermal conductivity. Cutting with diamond wheel.
