Hi there,
Yes, I am new here. I've spent quite a bit of time poring over many great-looking oven builds, and also searching for answers to my question. Now I'm hoping to get some more input. No, I have not started a build yet, but am just getting into the planning stage.
I love the idea of recycling old bricks where possible. I know about firebricks, why they are used, and so forth. I understand that they are the best choice. That said, I am very curious about using old solid clay bricks to construct my oven.
I have seen some references to people using pavers or other solid bricks instead of firebrick, but have not really seen any threads discussing or showing it in depth. Nor have I seen any threads about problems later, like spalling, etc.
Here's the deal. I have a neighbor who brought me a couple of used bricks from a scrap pile at a nearby college. There are two different types of brick there, and from what he tells me, easily hundreds of each.
One brick is red, one more of a brown color. They are both solid. The brown ones weigh slightly more than the red. The red ones are 7 15/16" long, 3 7/8" wide, and 2 3/16" thick (I don't know if these dimensions mean anything to anyone, but I am trying to be as detailed as possible). The sample I have weighs 5 lb. 8 oz., and has little "ribs" on it that I assume are there so as to gauge a mortar joint.
I split the brick so that I, and you, could look at the inside:
The red brick left a little dust behind when I split it, making me suspect that it is a bit softer than the other.
The brown brick is slightly different in size: 8" long, 3 3/4" wide, and 2 3/16" thick. It weighs 2 ounces more, 5 lb. 10 oz. and has no "ribs".
When broken, it did not leave any dust, and also seemed to break cleaner.
So what are the chances that using some of these bricks (I think I like the brown ones) will work out for the dome of an oven? I am thinking that I would still use firebrick for the floor, if just because it is new and clean, though I am not even sure if that matters. And if these are not good, what about actual old pavers, such as might have been used on a road, walk or patio? I often find these locally as well, and again, I would love to both recycle and use a bit of history if I can.
I thank any and all of you for taking the time to read this and look at the photos, and I will welcome any feedback.
Thanks!
Thanks!
. Think also about the pavers for a patio, out door kitchen floor, or walks through your garden. It doesn't look like there was any mortar used for there past purpose. Usually, it is just sand swept down into the joints. Lots of possibilities, if you can get them for a great price
. My first offer would be, "I can clean that mess up and dispose of it for you". I have actually been paid to "haul off" what I was really wanting to buy
