Hi All
I share a back yard with my brother, who just put up a homemade fb oven. I wasn't able to contribute as much as I would have liked, but I did get an oven door made. My own design, after digesting this forum a bit, and some other sources. Check out the pics. comments/input welcome
I like the BIG dial thermometer
and the 'thermal break' in the door to avoid transmitting heat to the outer layer.
It all came together quite nicely. the interior is calcium silicate 'block' which is actually 2" thick, and 1' x 3'. I glued it together with JB Weld, which is apparently heat stable to about 500 deg F.
the oven side metal is 'cold rolled' steel, painted with BBQ paint
the outside is stainless (a pretty penny at that!)
Took a while to find the thermometer, but this one works beautifully. the probe was the perfect length. I had to buy a stainless pipe thread 'coupler' from Tacoma Screw to attach to the oven side. this holds the whole door together.
all together this cost around $350, but I'm making up for missing out on the work to put the damn thing together (and what a project it was!)
Happy Baking!
Happy Baking!
