Bricks size
  • Bricks size
    Hi,
    After some search for bricks,i found yellow czech bricks.They are the best for heat.
    I found varius sizes.
    Which is the ideal for 36" oven?
    Re: Bricks size
    The 60mmx110mmx220mm are essentially the same size as those used in the majority of ovens built in the US. These are perfect for a 36" build.
      Re: Bricks size
      Nice!
      How many bricks to buy?
        Re: Bricks size
        Not sure for a 36" oven (mine is 39"). Check the forum for an answer to this. I'm sure its there somewhere. Your mileage may vary based on your entryway architecture.
          Re: Bricks size
          Which is your opinion for this specs of the bricks?
