Type K Thermocouple extension wire
  • strobes
    • Jul 2014
    • 62
    I'm looking for reasonably priced wire, enough to install 2-3 sensors.
    Extension wire is fine, I can located equipment to weld it.
    Any suggestions? Or you may have some extra?
    Thanks!
  • Audionatic
    • Sep 2014
    • 36
    Re: Type K Thermocouple extension wire
    I found mine on a popular online auction site. 50' roll of brown fiberglass-clad K type wire was approx. $35.00. I should have my thermocouples embedded in a week or so, if the weather allows.
    • strobes
      • Jul 2014
      • 62
      like this?
      Type K Thermocouple Wire with Fiberglass Insulation (482?C)
      • Audionatic
        • Sep 2014
        • 36
        some on there now thats even cheaper. Less than $15.00/25'.
        • strobes
          • Jul 2014
          • 62
          what is max. expected temperature inside the oven?
          • Audionatic
            • Sep 2014
            • 36
            Maybe 1200-1400 F.
            • strobes
              • Jul 2014
              • 62
              is the Fiberglass Insulation rated to about 500?C?
              • Audionatic
                • Sep 2014
                • 36
                I'm not sure of the rating, but it's what you'd use for higher heat and abrasive conditions, I think. The probes I bought are the 12" grounded type, so the wire and connections will be either in the insulation, or most of them outside the insulation in ambient temperature. I have a probe set into the hearth brick at 1" below the surface, and two set at the outer surface of the hearth brick, dead center of the hearth floor. These should indicate hearth surface temp, and gauge hearth brick saturation.
                There'll be another 5 in the dome. One just exposed at top dead center inside the dome, 2 set into the middle of the dome brick towards the front and back, and two more in the concrete cladding layer left and right, again to indicate saturation temps for baking.
                I'm pretty sure that wire will hold up well as far as heat goes. I'm more concerned with long-term corrosion at the connections to be honest, that's one reason I wanted a few redundant probes installed. I found a cheap, analog kiln gauge for $10, the 8 probes were $35, a used 8-position thermocouple switch for $10, and the wire, online. Good luck!
