Let me list the jobs I will have to do and help me to decide which product will be better for my needs
1 bond firebricks hearth with vermicrete base
2 bond precasted dome to firebrick hearth
3 fill inside dome cracks
4 render?
My question is if I can do all above jobs with castable refractory. Where I live I can source bonding and castable in 25 kg bags which is too much than my needs so I would like to buy just one 25kg bag. Castable is 48$ and bond is 65$ per 25kg.
from manufacturers webpage:
Grip- is an air-setting adhesive for bonding insulation products together, or onto refractory or steel surfaces.
Suitable for use with Ceramic Fibre, Insulation brick, Calcium-Silicate and Fibreglass textiles.
Cast- Low Cement and Conventional castables is extensive and is based on achieving the best user friendliness and performance properties. General purpose 1450 grade
4 render?
